Opinions, please
Bubba Hyde
Aug 18, 2008
I'm looking for opinions of Duramax technicians, or anyone else that deals with the workings of the engine control computer.
First, a little background. The truck is a 2003 LB7/Allison CC/SB 2WD. I bought this truck in April of this year showing just over 100k on the odometer. I figured with the life expectancy of the truck and the use that I would have for it I should be able to get several years of service out of it. I was a bit concerned about the injector issue, but figured if it became a problem I could get it handled under the extended warranty.
In June, I started the truck and began to drive out of the parking lot at work. Just before pulling into the main road (a busy 4-lane with a center turn), the truck died. Completely shut off, just like you'd hit the switch. Still had all the accessories (radio, air), so I thought I would restart it and be okay - maybe it was just a hiccup. So, I hit the starter - nothing. No attempt at cranking. Had it towed back to the dealer (thankfully I had a 90 day warranty), and after about 3 days of diagnostics they determined the PCM was bad and would need to be replaced. I thought that was a bit odd, but I left it in their hands. Picked up the truck the next day, and everything seemed to be okay. Warranty did cover the repair. I spoke with the technician, and asked if this was a common issue with these trucks, and he told me that this was only the second PCM he had put on a Duramax. Feeling a bit better about the situation, I went on my way.
Fast forward to August. I was reading some posts in the forum here and decided that I would get the VIN ran just for grins (thanks again ripmf666), and when the report came back I was floored. Turns out this truck has already had the PCM replaced once, at about 99,500 miles, by the same dealer and the same service tech. So, either the technician has a lousy memory OR he thought I asked how many times he'd replaced the PCM on this truck.
Now I'm worried.
So, I would like the opinions of those that deal with these trucks from a service standpoint on a somewhat regular basis. I've got a truck that ate 2 powertrain control modules in the space of about 2100 miles. Could there be something in the truck causing this? Is it just a weird coincidence? If this happens again, is the PCM a part that I can replace (I'm not an ASE certified technician by any stretch of the imagination, but I can turn a wrench should the need arise)?
Any opinions or experiences would be appreciated. Sorry for the long post, but I'd just like to ease my mind. Last thing I want is to have the truck shut off in the middle of the road and have my 15 month old in the truck with me.
Thanks,
Steve
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
FWIW
ECM,TCM and FICM can all be replaced with in a half hour with basic metric sockets
average cost would be less than 500 bucks each
Dont know if that helps you or not?
LarryJewell
Back with his honey :)
Jan 21, 2007
10,152
58
San Angelo
I had a similar issue, mine was faulty wiring of the Fass to the fuse block, somehow took out fuse block and the FICM also, but same type of symptoms as yours. Dealer did not cover mine since they didnt do the wiring.
Skyhigh4by
Goin to Poochisloose
Apr 13, 2008
408
Powell River, BC
If LarryJewel had his crap out from faulty wiring, could the original poster possibly have a short somewhere thats causing his PCM to get fried?
LarryJewell
Jan 21, 2007
10,152
58
San Angelo
what about the harness that rubs against the driver side fender well in the engine compartment? Could there be a sort in that bundle?
:confused:
possible, I wrapped mine in Bicycle inner tube a long time ago and zipped tied it secure to the support. FWIW, I had the dealer do the injector harness repair prior to it failing (and its never failed). I had the truck in for several maintenance/service things, so since I was paying for something, they didnt mind doing this under warranty.
