Opinions on this piston
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
Buddies truck
03 lb7 220k miles
Tore it down to do studs, gaskets, send the injectors to exergy to be honed, Hsp 366 kit, modded pump, profab manifolds and up pipes. Truck is a daily driver and he doesn't really want to push the lower limits of the rods. Bottom end wasn't in the budget this time around..
Question he asked was to keep running it or should he pull that piston and stick a stock on back in its home?
I've got a set of lb7 pistons and a set of lbz rods that if it was mine would go in it after the pistons were cut.
clrussell
pro-procrastinator
Sep 23, 2013
5,928
399
Replace it with a single used stock piston for now or?
Any idea on causes? It got ran a while with a bad injectors, never added fuel to the oil just hazed at idle. But that was 30k ago..
