One battery?
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
Who runs only one battery? my passenger one is dead, and id like to only run one. Here in az the winter temps are like 50-60*, and the truck is parked in the heated/ac'ed garage. never have had my glow plugs come on in 26k.
pros and cons?
DmaxHawk
Ranch with my Salad
Oct 28, 2008
699
the 575
I think GM put 2 batteries in there for a reason
Not sure what the pros and cons are but personally I wouldnt run 1:baby:
12secondhandshaker
<---Stock trans
Jan 21, 2009
146
Sparta, MI
I run one battery in the summertime as long as its above 50ish its no problem.
Make sure its a good one though! I flew out for a 4 day trip in the fall and it drained the battery and it never came back 100% I ended up replacing it(GM original) just before winter.
hondarider552
Getting faster
May 28, 2008
10,627
Arizona
thanks kat for the link, looks like i might be going to costco or walmart today then :)
I dont even trust 2 ac delcos.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
no. its titanium. (im not saying that to be funny ha ha, it actually says titanium on the side ill take a pic :) )
If you go into Advance and say "I want an OEM replacement battery for a dmax", its what they give you. I think it was 90 dollars.
Whitetail Addict
Rockin' the stock tune
May 8, 2008
2,350
South Central Pennsylvania
Just throwing this out there -
Wouldn't it be harder on the battery, starter, and glowplugs to run an LB7 on only one battery versus the LLY and LBZ?
IMO, at least in theory it would, due to the higher compression and glowplugs taking more voltage.
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
couple things...
the LB7 and LLY have the same compression.
Its hard on the battery yes.
not hard on the starter IMO
the LB7 glowplugs use higher voltage, but lower current. LLY+ glowplugs are only 4.7 volts, but draw roughly 2 1/2 times as much current...... 6 1/2 dozen or the other as far as I know.
ben
