ok i got a noob ?
maddogg101920
I break stuff
Mar 2, 2007
733
CECIL COUNTY, MD
this is my first time dropping an allison trans, do i have to remove the turbo....the way i see it theres no way in hell im reachin a couple bolts on the bell housing.
550
nope not really needed.
though if you really want you can;)
i got 40" worht of extensions a wobble 15mm 6 points and a impact and went at it.
i also dropped the tranny x-member this allowed me to get all the bolts from the back. you might have to do more diggin bc you got a t-case
paint94979
Beer Nazi
Sep 18, 2006
11,715
No, you do not have to remove the turbo. MikeL might be in the shop try to give him a ring.
maddogg101920
I break stuff
Mar 2, 2007
733
CECIL COUNTY, MD
ok thanks guys, i slaved at it for about 5hrs yesterday and i only have the top 2 bolts left, but i figured what the hell it cant be that hard to remove the turbo, plus i have a diamone eye downpipe im gonna install after i drop the trans...i got stuck on the EGR bolts were you have to put the blocker plate in, they seemed a lot easier the first time i put the blocker plate in and now i cant seem to break them lose.
custom8726
2,784
Upstate N.Y
Like MALIBU suggested use a couple long extensions and you can sit at the tail section and remove the top bellhousing bolts with ease. The first time is always the hardest. It took me 4hrs the first time doing it off jack stands with a motorcycle jack for a tranny jack. This last time I had the tranny and T.C. out in 1 1/2 hrs. Good luck!!!
last_one
Mar 22, 2008
57
here is a pretty good pic of getting these babies out.
Jared Duramax
<---- $$$ Whore!!
Feb 13, 2008
1,052
Matthews NC
i was dropping mine this afternoon just sit behind the rear cross member and have at it with all of your extensions and all your friends extensions also:D
MAXLLY
No Lemming Here
Aug 15, 2007
1,063
San Diego
I didn't take my stock charger out either. I used a VERY long extesion and went at it from behind the crossmember, closed one eye so i could see over the top and got 'em all first shot.
When i put it all back togehter i replaced the bolts with double ended accessorie studs, that way i only have to get the socket on the stud and squeeze the trigger, it'll fall on the bolt and use the stud to center/locate the socket.
Good luck.:)
