On your truck its #40 in the pic added here attached to #41. There located towards the back on the LLY thru LMM blocks.
The 01-02 is located there, 03+ is located furthur back like the LLY+ is what I thought. As for the guage, most likely it is the stepper motor in the cluster that is failed which is VERY common on the 03-04 trucks.
does anyone know the test procedure for the lb7,my gauge reads 60lbs all the time, NAPA wants 129.00 for this sending unit and i want to make sure its not the cluster.It has three wires going to is,and im pretty sure 1 goes to the computer,tho not sure.
