I was under the truck looking things over and noticed my oil pump is rather noisy, I heard the noise before the engine was tore down but never paid attention, any reason an LMM pump would be loud? Oil pressure is 60 psi cold at idle and 25ish hot.
hearing a "whine/buzzing" noise when warmed up?
I’ve searched for hours, so it’s either f’ed up pump gear or some metal is taking the pump out, there was some real fine metal in the oil filter when I did my first change, didn’t put a magnet across it like I should have, I’ll change the filter this weekend and see what it looks like, I figured it was just everything breaking in as I’ve seen it in other motors.
Did you do a complete rebuild with new rings and bearings?
If you did a complete rebuild, I was told about 30,000 miles before making the change over to synthetic.
