Oil prime
ikeG
Oughta Know Better
Apr 19, 2011
2,445
139
Western PA
www.facebook.com
Has anyone had to fix a apparent oil prime issue? After sitting overnight, this 2021 will take around 15 seconds to build oil pressure. Which brings up the shut off engine warning on the DIC. It has new Rotella T4 15w40 and a PF63.
A google search brought up some threads on duramax forum that a couple had cracked oil pickup tubes. I cant find any TSB regarding it. I suppose i should just start tearing the oil pan off.
PureHybrid
Isuzu Shakes IT
Feb 15, 2012
3,434
442
Central OH
Can you see any damage? My brother noticed a damaged valve on a Wix he bought last year for his 2022. Never had an issue with low pressure at startup though
darkness
1,297
365
vegas
The pf63 is the new replacement for the pf26 right? Hope there wasn’t a bad run of those.
5,603
I’m still using the 26’s here. I think I tried a 63 on my truck currently. It’s due for an oil change and no pressure issue.
Hopefully just isolated to that one filter!
darkness
1,297
365
vegas
My fault, I must’ve read something wrong or it was a different post that someone had an issue with 2 filters in a row. I have a 63 on my truck now.
1,802
Did GM do the same stupid thing with the L5P oil pickup that they did with the first Cruze diesel? Used an O-ring seal between the pickup and the block/oil pump?
ikeG
Oughta Know Better
Apr 19, 2011
2,445
139
Western PA
www.facebook.com
I have yet to have one apart but schematic looks like pump seals to upper pan vertically. Then the pickup tube inserts into the upper pan from behind, but horizontal. Without a seal. Looks like they are prone to cracking right at the bevel that it seats on when inserted the entire way.
Sent from my SM-G990U2 using Tapatalk
ikeG
Oughta Know Better
Apr 19, 2011
2,445
139
Western PA
www.facebook.com
Got the lower pan off and found the pickup tube is fine, unfortunately. There is some weird dried up sealant in the cavity where it presses into the upper pan. Maybe some of it got sucked into the pump. I'm unsure at this point.
