As said above, no steppers in an 02 cluster, it's a plane jane air core motor. It has a ground, power, and the variable wire coming from a 1 wire sender to it. It's a double sided magnet motor, 1 side is powered and grounded all the time, the other side is powered, but receives it's ground from the sender. When theres an open circuit from the sender, the oil pressure gauge goes fully over towards the 3 o clock position, as the ground from the sender is applied, the opposing force pulls it back over. Very simple design. Since yours is going to the 3 o clock position, you know it's powered, but most likely not receiving a ground signal from the sender. Unplug the sender(1 wire plug on the lower forward drivers side of the block on an angle adapter pointing up iirc), and ground the wire, turn the key on, and the gauge should read 0. If it does, then your sender is bad, if it doesn't you most likely have a wiring issue as air cores RARELY fail.
