2005, 2500 LLY. Pressure sensor has been changed twice. Stepper motors in dash have been rebuilt. Engine runs fine. Problem is intermittent. When cold oil pressure is above mid way and drops to just below 1/4 when hot except when problem arises. When the problem arises pressure drops to 0 at low idle. 2 times in 4 years oil pressure dropped to 0 and the alarm stayed on until truck was restarted the next day. The truck was taken to a dealership and there were no codes and the oil pressure system responded normally.
I believe the issue is most likely a wiring issue. Where can I find a wiring diagram for this truck?
