Oil Line
dmaxfireman
'Can do' kind of guy
Apr 8, 2007
2,329
CT
i have not but i'm pretty sure you could make one out of copper plumbing pieces faily easily. just need some sort of flex piece on the horizontal piece as close to the turbo side as possible in order to clear the up-pipe flanges.
Jared Duramax
<---- $$$ Whore!!
Feb 13, 2008
1,052
Matthews NC
some one just posted on here the other day about getting a fitting to work with out using the banjo ill see if i can find it again
paint94979
Beer Nazi
Sep 18, 2006
11,715
yeah, gues I have to talk to sales guy. Didn't have luck on site. BD S300 is not the same.
it is still an S300 that is my point... the BD one will work perfect. I am sure you could make one cheaper though
dmaxvaz
wannabe puller
Nov 22, 2006
1,132
46
METRO DETROIT
it is still an s300 that is my point... The bd one will work perfect. I am sure you could make one cheaper though
it is not a s300. Its is based on a k31 turbo(s400 comp cover, 71.5 comp wheel, and a special exhaust hsg(tight a/r).
Vrabel
TOYAHOLIC
May 22, 2008
3,434
57
Hewitt, NJ
Ok, once again was blown off by ats! Do you think running a larger line from galley insted of valley would have a negative inpact? Meanining too much oil pumped into bearings and making a seal leak.
Jun 28, 2007
3,259
NE Pa
It shouldn't. I don't know squat about ATS turbos but if they are BB they should have an oil restrictor built in and if they are journal bearing it wants lots of oil.
othrgrl
Diesel Addiction Owner
Mar 10, 2008
2,151
Wilmington NC
www.mydieseladdiction.com
From what I understand the new A5K kits come with oil supply lines that feed from the galley. Fleece has a kit that would work for you, give them a call.
juddski88
Freedom Diesel
Jul 1, 2008
4,658
128
Chesterfield, Mass.
from what i have read, only a larger line from the valley in lly+ blocks would negatively affect oiling to the #4 cam bearing. lb7 blocks, from what i could make of it, were not having the issue of starving the #4 cam bearing even with aftermarket oil feeds from the valley. I am not positive if it was just a difference in cam design (oiling groove in lly+ cams ?) or combo of that and difference in factory oil pressure, or what.
