So I finished my headgaskets, added ppe manifolds and up pipes. and installed a oil supply reroute from the port in the block near the filter. Return pipe is braided 3/4" hose and no restrictions. Turbo was rebuilt and ww2 was installed. When I first start the truck up. The oil pressure is between 70-80 psi according to the instrument cluster. I guess this is too much pressure for the seals on the turbo. It starts leaking from the v clamp holding the down pipe to the turbo. Once the engine warms up and the oil pressure drops to normal (30-40) No leaks? I just replaced the oil with T5 10w-30. So should I install a restriction fitting? I dont want to starve the turbo, but I dont want to keep pushing past the seals. Please help, any suggestions
