I had a leak in that area, I thought it was the filter adapter. cleaned it with brake cleaner, starter the truck but no leaks at the adapter. it turned out to be the bottom gasket on the valve cover. had it replaced and about a month noticed the small drips of oil again. turned out I had bad injector(s). I don't know for sure of it was a bad install on the new gasket or the faulty injector that was causing the oil leak again, but my friends and i figured since fuel was mixing with the oil it was making it thin enough to get by the gasket, but dealer replaced all 8 under the 200k warranty and its been over a year and no leaks
