It seems I have a small oil leak cant tell where it is coming from but it drips right where the front drive shaft bolts to the front diff. It comming from right above that spot and cant tell if it is like the rear of the block like a rear main seal (not sure if these even work like that) or around the oil pan... Truck only has about 5 k miles on it. Anoyone know of this or if seen this before from these new d max's. Thanks for your input.....
