Oil flow volume (hot) with stock oil pump
jpowel29
780
Bentonville, Arkansas
I am trying to spec out the correct Oberg filter set-up. The one I am considering flows: 20 GPM through a 60 micron filter (based on 20x-50 oil at 180 degrees).
There is one size larger that flows 37gpm. Anyone know how much a stock DMmax oil pump pushes? How much a Delco spin on filter would flow?
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
If nobody has a answer here for you , I would ask Rick D I bet he would know.
If you do find out post it up please.
keith2500hd
MOTORKILLER
Jul 20, 2008
57
Burlington,iowa
sabre marine used to run 2 parallel flow mounted on side of block, i think they used to run sandwich plate with course rated screen to catch large particles prior to fine screen. sabre marine ran ford tractor 366ci(english built) in early 80's. i like the oberg over the trashcan types because you can see if it is clean.
