anyone else see this article on the DP about a oil filter collasping?
http://www.dieselplace.com/forum/showthread.php?t=333429
The guy is full of shit.
First of all, the oil lubrication system in the dmax isnt under vacuum. Unless physics has changed, something cant "collapse" with positive pressure being subjected to the inside of it.
Second of all, the ECM does NOT SHUT THE TRUCK DOWN if oil pressure drops to zero. Go try this by unplugging your oil pressure sensor, and start the truck. Guaran-frikkin-tee it will start dinging at you and say "OIL PRESSURE LOW" in the driver info center but it will keep running.......
ben
Also I thought the system would pressurize the filter...not collapse it..
