oil drain plug torque
magnethead494
go fast crew chief
Dec 29, 2013
222
35
Fort Worth, Republic of Texas
took truck in for it's first-to-us oil change. PO worked at dealership, all servicings occurred there as well.
Took it to our preferred place, the guy couldn't get the plug out with a wrench or ratchet, had to use a 3 ft breaker bar to get the plug off. Said the threads looked fine, did the oil change and went on our way. Get home and it's dripping, hit it with a wrench and had another 1/4 turn in it. Looked at it today and it's still dripping, but not much.
How many in-lb should it be torqued to?
13,713
773
62 ft-lbs. Did they put the copper washer back under the plug?
GeorgiaDieselGTO
Wants to drive his truck
May 12, 2010
102
Crossville
I would guess washer missing as well.
Ya gotta live people who think a drain plug needs to be as tight as they can pull it with a breaker bar
Big Block 88
Multiple choice muscle
Nov 3, 2008
4,665
Kansas when I am home
Copper washer is most likely destroyed if it is still there. The truck I just got took a 3 foot breaker to break loose and it dripped when I buttoned it up.
Washer was misshapen and gouged I replaced it with a fumoto
IronDX
213
I never torqued a oil plug. I just made sure it was tight, & checked it every now & then.
