oil cooling
Accelerator
On a Time Out
Mar 12, 2009
242
Lets talk about the oil's ability to cool the pistons and resist shear.
Questions.
what viscosity offers better cooling or heat transfer?
What viscosity offers the best shear strenght?
15,681
233
Questions.
With all of your championships that you list in your sig; why don't you post some facts instead of asking us dummies questions?
Post your choice in oil preferences and then we can shoot you down or agree. Or don't you know?
dmaxvaz
wannabe puller
Nov 22, 2006
1,132
46
METRO DETROIT
Questions.
WHAT IS 'SHEAR"? ARE YOU ASKING LIKE WHEN IT TURNS LIKE THE CONSISTANCY OF WATER?:confused:
Accelerator
On a Time Out
Mar 12, 2009
242
Im asking because i want your opinions on what you think works best.
Viscocity is the thickness of an oil and it's resisitance to flow.
Shear strenght is the oils ability to resist metal to metal contact.
i feel that these are most important in a performance d-max engine
persoanlly im trying to deside between these oils
redline 50wt
amsoil 15-50
amsoil 15-40
dmaxvaz
wannabe puller
Nov 22, 2006
1,132
46
METRO DETROIT
im asking because i want your opinions on what you think works best.
I feel that these are most important in a performance d-max engine
redline 50wt
amsoil 15-50
amsoil 15-40
you should add shaffer's 15-40 to your list, its some good stuff
The Neens
BFD
4,596
Monrovia, Ca.
This is what I run in our 7 second blown alky SBC...
http://www.bradpennracing.com/history.html
The 50wt has plenty of cooling and anti-shear characteristics...In fact, our billet forged billet aluminum rods look new after 75 passes at over 180 MPH...Rod bolts are f'n garbage, but the rods are pretty...I'm gonna call ARP and raise a stink...Our oil temps raise approx 10* during a 2.4g 1/4 mile pass...I'd say that oil is a winner:D
Not sure how this is related to a turbo diesel, but who cares, I think I'm bitchin':beer2:
Sorry if I touched a nerve:thumb:
racinmike77
Sep 14, 2008
1,029
MD
I run the 20w-50 Brad Penn also in the race car. Its fairly cheap at $50 a case or 4 cases for $160
keith2500hd
MOTORKILLER
Jul 20, 2008
57
Burlington,iowa
i think if your looking for oil for racing diesel, use 5w40 or 15w40. syn or dino your choice. in a race gas engine the rotation assy can live with loose bearing clearence and use high viscosity oil to make up for proper clearences, but a diesel engine the high(operating, consider static and operating compression; static plus airbox pressure) the ignition under high pressure will shear the oil out of the bearings and pound them flat, leading to total loss of oil pressure, engine failure. i was always taught to use minimum viscosity to get desired oil pressure, saves engine from eating itself away. thicker oil will cause components to fight and use more HP to move, drag racing might get away with this, but i think you might get longevity and sustainable HP from an engine then loosing it up. i have a customer that gets his boat engines rebuilt every couple years, the rebuilders have him use 20w50, his engines start to run crappy and start to smoke towards end of 1st season. JMHO concerning oil cooling, having engine loose oil will flow quickly thru engine, same as not running a thermostat(flow control) in coolant system, oil won't have time to pick-up or give off heat from contact surfaces in engine. oil is primary coolant in engine that distributes heat to more surface to allow outside coolant(air or water) to pick-up and transfer from engine.
mytmousemalibu
Cut your ride, sissy!
Apr 12, 2008
2,230
Kansas
:rofl: Ive used our VR-1 50wt in my truck:D No problems, im happy! Stays nice and gooey even nice and hot!
OT, but what rods you run Chris? We ran Howard's, but there ARP bolts too.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
Sounds like you need some way better bolts Chris:D
My rods have bolts made from T-11 tool steel, i think:confused:?Boys at cunninham refused to use ARP junk ( there words, not mine )
As far as Wades topic.....There is a thread that allready has same info
Search racing oil;)
Im trying to get some Cen-pe-co here in Canada and ill swap to that in the 50wt
