The internal dia. of the fittings for the Amsoil are small for what we are pumping (ID of the fittings the hoses connect to). It diverts ALL the oil through it in which the internal dia of the fittings should be no smaller than about .550 (cutting it close and .600 being better, or 3/4" ID hose for the ID of the fittings to flow the correct amount) to get full flow at the higher rpms of what the pump flows. This increases velocity through the system at the same pressure. When doing this, it is better to have a recessed oil seal seat (like the Allison has for it's filter). You can have this done at most machine shops. I believe the side oiler is the way to go for full flow and no compromises. This is what my Purifier uses. It takes a small sample from the oil galley and sends it to the small mic filter then returns through the filler neck (side not the fill cap). Amsoil was on target with what they did, but they should have set it up different. I read the stock oil bypass in the filter was set up at 64psi. Not sure though. Never tested it. I shimmed the one in my oil pump.
