Question: Oil and Fluid info/suggestions
Whitetail Addict
Rockin' the stock tune
May 8, 2008
2,350
South Central Pennsylvania
I have been reading up recently on CI-4 vs CJ-4 oils, and synthetic vs mineral oil. I read that the difference is in the additives between CI and CJ, mainly sulphur-which from the way I understand it is what protects against wear. CJ has less due to clogging the DPF on new trucks.
Is there any known additives to add to CJ-4 to get the zinc back? What is your take on this, and the synth vs mineral debate?
Also what fluid do you run/recommend for use in the Alli, the transfer case and the differentials? Most of you guys on here run your trucks alot harder than I do so I was curious how you protect your Dmax and the drivetrain.
P.S. -mods feel free to move this if it is in the wrong section.
