Here are the specs, when I got mine it was 299 + shipping
Brand New...100% Aluminum, hand welded, constructed with a bar and plate design. Polished finish intercooler. Perfect for your next turbo project or upgrade. Buy direct from importer and save BIG.
Air/Liquid intercoolers run by pumping cooled water through cores either from a front-mounted radiator / heat exchanger or chilled water produced by circulating the liquid through a container filled with ice, as used in quarter mile applications.
Good for up to 1500bhp. all our intercooler has been tested to withstand more then 80 psi pressure and it has very small pressure drop across the end tanks, at 15psi inlet the out let has 14.8psi that means it has only 0.2 psi pressure drop ,compare to many other intercoolers it is an excellent figure (some intercooler has 1-2psi pressure drop) also at the same condition, the temperature has drop from 120 degree to 28 degree ( and it is an excellent figure for efficiency)
Core Length :9"
Core Height:10.5"
Core Thickness:4.5"
Inlet Size:3.5"
Outlet Size:3.5"
Overall size(with endtank): 16.50"x12.8"x 4.75"
