This is making me wonder if here is the loss of MPG? Restricted air flow. I wonder if the loss of air flow is making the rad. fan work harder? Unless you are running elect. fans.... then never mind.
jc
no mechnical fan with a hyden clutch..
If your truck is already getting up to 180, you probably don't need to block the airflow. That is where mine runs in the summer unless I have a BIG trailer behind it. 195 means you are on the 2nd thermostat, and it is almost running too hot, IMO.
Messing with pilot timing might be beneficial. I am starting to play with it on mine, but I don't understand the effects well enough to give a good recommendation on how to adjust it.
OEM spec hot dmax is 250* very hot is 255* hotest i have had these was 215-220* pulling a 5% at 26,000lb (fancy gap NC) at 68mph
last week had the chane to run in 30* temps without the plexiglass i was lucky to get 175-180* cruising down the road with a rolling weight of ~22,000lb put the plexiglass in and im up around 185-190 if i stopped for 5 minutes(example park left runing at a rest area to go in come out) i go from 190 to 145* in 30* weather w/o plexiglass with it it take about 30 mintues to drop 45* at idle..
here is picture of said load.. actually was starting to snow in trenton nj when i picked it up headed to lima oh
pilot injection serves two functions..
soften the actual combustion noise think 12v 5.9 rattle it has no pilot injection same with a mechanical 6.5/6.2
and pre heat the air to create a better burn of the main injection for the most anything less then 75% throttle lbz in stock for run to 100% throttle
