Info: Offset help please
Jonesin33
Aug 26, 2011
189
TX
The lift is coming off and going different route, 17x9 with 0 offset... That is the rim I found I would really like to go with. Is this look possible with that rim? 6 inch lift coming off and DJM 3/5 drop going on. Advice, input, thanks!
Sick truck whoever owns this, didn't get his name.
Sent from my DROID RAZR HD using Tapatalk 2
whitetrash21
put on da damn helmet day
Apr 29, 2008
4,929
Vegas
If that wheel is made in 0 offset, ot should work.....depends on how much tire you try to stuff in there. Might require a little fender well massaging. Offsets start get a little more tricky the more negative they are. 0 offset should be 4.5 " backspace on that wheel which will work.
maine dmax
Mar 28, 2009
127
Mine currently is a 3/5 DJM drop, 20x9 BMF stealth, 5.5 backpace, 305/50/20 420s. Looks real good, dont stick out much and wheel is tucked up into well, so turning is pretty good. I also removed overload leef to get it lower
