OEM trailering harness
Atouchofgrass
Jun 19, 2010
526
CT
We'll our lb7 we bought about a month ago came with from the previous owner an aftermarket trailer hitch and a four pin plug in. I unwrapped the electrical tape, and what it looks like is he just cut out the stock plug setup. All the wires he didn't use was caped and taped, does anyone know if i can get an oem plug harness that goes into the back of the oem 7 pin plug? I tried looking on gm parts direct and they only have the 7 pin plug or the actual hitch, couldn't find the electrical. Thanks for your help!
Atouchofgrass
Jun 19, 2010
526
CT
See i was looking at that, but do i need too splice all those extra wires into the taillights etc or will they plug together with the stock harness?
trailerpro
Junior Member
Aug 6, 2006
150
Salem, Ohio
Since you said the original owner hacked off the end of the harness, yes you will have to splice this new harness to the original tow package wires. You have to use the factory tow package wires because they are different wires than the ones that run the truck lights.
trailerpro
Junior Member
Aug 6, 2006
150
Salem, Ohio
jlawles2
1,057
Danbury, TX
  • 1999-2007 CK,Wiring Harness,:Camper, (UY2) - TC02651.pdf
