Odd transmission dash issue
slowlb7
Feb 10, 2014
135
des Moines iowa
I replaced the neutral safety switch and pigtails. Tried 2 different dashes, but the "D" on the dash doesn't get the square around it like the other gear indicators do when in the gear. The transmission goes into drive and it drives fine, just doesn't show that you're in Drive on the dash. Does the neutral safety switch just tell the TCM what gear you're in, and the TCM tells the dash? Or do the wires split, like a separate wire for each?
slowlb7
Feb 10, 2014
135
des Moines iowa
Any else had this iusse still can't get it fixed and the shops/ dealer want way more then I'm willing to pay when the truck still drive fine
3,729
297
I've seen that before on older gas trucks when the NSBU wasn't aligned properly. I don't know if it can be misaligned on the Allison or not, but might be worth checking into.
Sent from my FlashScan V2
KyleC4
470
Bay Area
Honestly I think you need to have someone with a tech 2 look at the data. Only way to be sure all ranges are matching correctly. A nsbu switch can be slightly misadjusted but also a misadjusted trans shift cable can cause a misreading. That's why I think need to have a scan tool hooked up to be certain.
