O2 sensor
Henry95
283
Doing my own duals and was wondering does anything different need to be done with the o2 sensor when you go from single to duals. Had a guy tell me I could not just run it in one side. But I don't see why I can't.
93 Dakota mud toy.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
Does that one use 1 or 2 O2 sensors now? Can't rememebr, but I thought it used one upstream before the cat, and one after for 93. If so, then it is best to run the 2 pipes into one before the cat, split it coming out of your muffler, and run your downstream between the cat and muffler. Otherwise you can put the downstream anywhere, and put 2 anti foulers on it between the exhaust to stop it from coding.
Henry95
283
Only 1 sensor on the 1st gen dakota's. Before cat. Cat and stock muffler are long gone.
