NSBU bad?
Porno Joe
513
South of Pittsburgh
i just installed a transjo jr in my lbz 6 speed. I THOUGHT i did everything right. put the truck back together and its in "limp mode" i guess, dont know as i never had limp mode before. but when u put it in D its locked in 3rd. first time I pulled codes i got a bunch, thinking maybe due to the fluid all being run out. Second time I pulled codes, I got two. PO700 and PO877.
Also when the truck is sitting off, Im not getting any chimes with key in or lights on.
Could my NSBU be bad? or did i hook something up wrong?
Porno Joe
513
South of Pittsburgh
ok to update, i pulled the pan off, all connections are tight, I didnt drop the valve body. put it all back together and im still stuck in limp mode, and getting the 877 and 700 codes.
How do u know if the switch is adjusted properly? this is a 6 spd so the switch is on the inside
Lb7KID
ZoomZoom
Jan 24, 2010
274
parker,colo
ohhhh i did not no that the switch was on the inside of the 6 speed. im not sure how you would adjust that one. i will do some digging around and see if i can help come up with anything sorry about that man. i no i hate the p0700 haha it is the devell
15,681
Switch is automaticaly adjusted when it bolts up. In what order did you install the trim solenoids?
Porno Joe
513
South of Pittsburgh
umm, i dont remember what order? i followed the transgo instructions as well as the how to on here.
i keep getting the PO877- trans fluid press sensor/ switch D circuit low
what is that on the valve body? could it be a piece of dirt in there somewhere?
durallymax
Apr 26, 2008
2,756
Under The Hood
Take out the Pressure Switch Manifold. Its the Blueish colored thing with a plug in it held on by a few bolts, on the passenger side of the valvebody by the trim solenoids. Its a decent sized piece.
More than likely the o-ring for switch D shifted and/or broke when you reinstalled the PSM. Just had this two nights ago on an LMM and know of a lot of people having this issue on 6spds for some reason. Simple fix.
13,712
773
I had the same thing Vinny said happen to me the first time I worked on my transmission. AFAIK, that o-ring isn't available by itself. I tried a universal o-ring out of an o-ring kit, but after it was in there for a few months, it failed. I had to buy a whole PSM from Allison. If memory serves, it was somewhere around $50.
Porno Joe
513
South of Pittsburgh
ok i got it fixed. Im actually not sure what was wrong with it. I had the solenoids in correctly, i pulled everything apart and basically started over. Im thinking maybe i had the two valves from the transgo kit in backwards ( one with the rib in the wrong hole.)
Thanks for your help!
15,681
Those valves cannot be crossed. They are different diameters. Glad you fixed it.:thumb::D
durallymax
Apr 26, 2008
2,756
Under The Hood
Dont the trim solenoids on teh 6spd have different bores for the actual solenoid so you can screw them up? I could be worng I just though it looked that way.
Porno Joe
513
South of Pittsburgh
hmm, I thought the solenoids were different size but I wasnt sure.
well, if they cant be crossed, then I honestly dont know what I did wrong the first time? maybe a piece of dirt or something somewhere, because it all looked correct as I tore it apart.
all I know is I put about 50 miles on it last night, and all is well. So whatever was wrong is now fixed.
