nother newbie
Ralph
Aug 5, 2011
3
KY
Found this spot on the web while reading on another Forum. Like it plenty. Old guy from KY here. Finally bought a diesel and now am learning all the joys of ownership. I know many of you will be surprised to find out my LLY overheats when I tow...let's not go there. I'm working on it a little at a time. Going with a tranny cooler next. Each mod gets me a little closer...
Site is very interesting...:)
Kspen90
<<<got turbos?
Jul 14, 2011
1,433
Burleson, Tx
the turbo inlet/mouthpiece mod will help drastically with your over heating problem and theyre pretty cheap and easy to install
1953drtelco
223
Riverside, CA
I was in the same place a couple of years ago, I started out first by replacing the stock MP with a LBZ MP (Helps, but will not solve the problem. I can tell you from experience the real solution.. . See the link below for a complete solution for your overheating problem..If your looking for a larger tranny cooler...Check out Mike L He is a vendor here and his tranny cooler works as advertised.
http://www.dieselplace.com/forum/showthread.php?t=371427&highlight=
