This may not exactly answer your question, but it may help understanding the problem if there is one.
The fuel pressure is electronically controlled by the Fuel Rail Pressure Regulator (FRPR). The
FRPR is a duty-cycle solenoid mounted in the pump and controlled by the Electronic Control
Module (ECM) based on feedback from a sensor in the junction block that provides fuel to the
supply rails. The FRPR duty-cycle operates in a 5 to 95 percent window, and unplugging the
solenoid drives the fuel pressure to the maximum level instead of vice versa, as we might expect.
The ECM increases pulse width to lower pressure, so if the solenoid receives a 100 percent dutycycle for some reason, pressure will be at its lowest, and performance will obviously degrade. A 5 percent duty-cycle will produce a fuel pressure of 23,200 psi, and a 95 percent duty-cycle feed will produce a 5,000 psi reading. The pressure should never go below 3,000 psi; if it does,
something is wrong. The Tech 2 scan tool provides target and actual fuel pressure readings for
diagnostic purposes.
