Noob efi live problems!
Yaryan92
Nov 30, 2014
56
Prineville OR
So i just put a pre tuned ecm in my truck. I recently had a edge evo cs. i set my edge to stock and hooked up the dsp5 switch. it feels like its not switching tunes tho. im pretty positive i put the pins in right, the little selector washer did fall out back i think i got it put in right. Any help on wherr to start diagnosing?
i have my edge plugged in for gauges could thst do it? sorry for bad spelling and if thus doesnt make sibce shouler surger6y yesterday
Awenta
4,090
CT
Check voltage across switch pins
Was the ecm set to switch with dsp or the edge?
Awenta
4,090
CT
You can ohm out the switch and the resistance should change with each setting.
You should have 5 volts also.
Awenta
4,090
CT
What kind of scan tool? If you can see injection data you will be able to determine if the tunes change or not.
It shouldn't be stuck on the race tune unless you have the selector ring on wrong.
A. Stock Lbz
Aug 13, 2013
342
spokane wa
If the base tune is the race file it will run off that tune if there is no switch hooked up.
Op does the edge have tuning on it still?
Yaryan92
Nov 30, 2014
56
Prineville OR
its a genisys scan tool. i cant remember if it can read that or not.. i changed the selector ring made sure it was turned all the way clockwise. its def on a pretty hot tune.. its smoke s like a freaking train :( which i wouldnt mind at a track but im not to fond of looking like a jackass around town. could my edge have screwed it up?
Yaryan92
Nov 30, 2014
56
Prineville OR
No i set it to stock before we switched the ecm out. Its unplugged now.. i tried plugging it in to use just the gauges and when it loads it says someting about the operating system. the gauges work but i havent tried using the tuning features..
Yaryan92
Nov 30, 2014
56
Prineville OR
When it was in the other truck the switch broke and it was stock on #3. it also came out of a 04 lb7. mine is a 02. Everything works fine on both trucks besides me not being able to change tunes.
Yaryan92
Nov 30, 2014
56
Prineville OR
Unhooked everything plugged it all back in and checked voltage off switch. now all positions are showing a change in voltage.. Also i noticed the red and black wires were backwards in the ecm. could this have been this issue? still havent takin a test drive but hoping for the best. thanks for all the help and info...
