No tow haul not the switch
07keo02
Oct 5, 2011
399
Phoenix, AZ
Noticed tow haul doesn't work in the 02 I just picked up. No light on dash and can't tell a difference in shifting. I pulled the shifter and checked with a multimeter and it's working fine. What's my next step?
1,944
Broken wire inside orange sheath, usually at the black clip that holds the wire to the column.
07keo02
Oct 5, 2011
399
Phoenix, AZ
Sorry, I should have specified. I tested at the end of the wires, at the clip and got good indications on the meter that the switch was working. I also moved the wires around while testing and it worked consistently.
07keo02
Oct 5, 2011
399
Phoenix, AZ
Just jumped the connector where the switch goes in and still no luck. Is there a way to do a panel light test to make sure they are all working?
duratothemax
<--- slippery roads
Aug 28, 2006
7,139
Wyoming
Did you try jumpering the tow/haul signal pin at the BCM? Just to rule out a wiring issue between the connector and the BCM.
Yes, you can do indicator tests, but you need a Tech 2.
07keo02
Oct 5, 2011
399
Phoenix, AZ
Haven't tried that yet. I'll have to do some searching to figure out where to jump. Last night I drove it in varying conditions trying the button with no change so I am ruling out the light.
07keo02
Oct 5, 2011
399
Phoenix, AZ
Just jumped from the black wire on bottom and the light blue on top and no dash light indication.
07keo02
Oct 5, 2011
399
Phoenix, AZ
I believe in my picture above is not the BCM . Do the wires make they're way to the BCM after whatever the assembly above it is?
ecc_33
Junior Member
Aug 10, 2006
1,925
Amanda, Ohio
What did you exactly test at the switch? Did you test for voltage at the switch or did you ohm out the switch itself to make sure it was working fine? Kinda confused on that part.
07keo02
Oct 5, 2011
399
Phoenix, AZ
At the end of harness of the shifter, while disconnected from the truck I put a lead on each pin in the connector testing for continuity while pressing the switch. After I confirmed that, I jumped the connector in the truck where the column harness plugs in. When that step didn't work I went further and jumped the wires shown in this photo ( light blue towards top and black towards bottom). This assembly (not sure what it is) is located just above and to the left of what I think is the BCM.
ecc_33
Junior Member
Aug 10, 2006
1,925
Amanda, Ohio
It is a light blue wire to the bcm. Pin B12 wire number 553. Looks like after it goes through the TH switch is goes to a body relay block under left side of dash.
07keo02
Oct 5, 2011
399
Phoenix, AZ
Much appreciated. Could you tell me where the other wire goes into the bcm? I'm assuming it's black. I will try this later today.
ecc_33
Junior Member
Aug 10, 2006
1,925
Amanda, Ohio
from that body relay block it goes to the which turns into a black wire from the TH switch to the body relay block. Then it continues to be black and goes to ignition key alarm switch. After the ignition key alarm switch the wire turns into a light green wire. Wire number 80 pin B9
07keo02
Oct 5, 2011
399
Phoenix, AZ
Thanks, major help so far. I do have an issue with my ignition. They key will come out even while it's running. I wonder if the ignition switch you are referencing could be an issue.
