Checked all connections at both ends, all looked good but cleaned anyway. Was told a there are 3 trouble spots for harness, gotta check those and pull harness to check it all. All codes point to a wiring issue but could nsbu do it or a bad TCM?
It happened on start up first got it to come out of limp drove to work fine, left work did again, shut off couple times came out if limp drove 20mi normally then right into limp at a snap of a finger under no load, drive another 15mi in limp and boom right out of limp and drove home with no issue. 1 hour later start up in limp and been there since.
