No SPARK ?!?!?!?!
cketcc
Aug 9, 2014
indiana
i have a 2003 chevy silverado 6.6
had to change my injectors the other day got them done plus batteries we old so i replaced them too !!
NOW !!! when I go to start it !!! It wont SPARK at all !!! Does any one know why this would be happening ? Or even a site I can go to to try to find out why ??
Thanks :(:mad:
cketcc
Aug 9, 2014
indiana
ugggg
and just to add because i just noticed this !!! tried to turn truck over and it blows a lil smoke out not a issue... but 5-10 mins later im looking and it and it has a lil smoke coming out !!!! when NO ONE HAD TRIED to turn it over :confused::confused::confused::confused::confused::confused::confused::confused::confused::confused::confused::confused::confused::confused::confused::confused::confused::confused::confused:
e46_330i
140
Youngsville, NC
Uh.. It shouldn't have had spark before the injectors were replaced... If it's not starting you probably don't have it primed.. Prime the filter head.
cketcc
Aug 9, 2014
indiana
yea tried that.. got it primed went to turn it over it tries to turn over and NOTHING !!!
everything ran great !!! untill after i changed the injectors.. very frustrating Im getting no codes
paint94979
Beer Nazi
Sep 18, 2006
11,715
Have you checked fuses? Do you have access to efi live so you can determine if you are getting adequate fuel psi?
cketcc
Aug 9, 2014
indiana
so this is were we are at now !!! the truck started and stayed running 30 seconds then died !! then if you wait a few mins it will do that again !! by chance do you have any suggestions
1,866
Hot COCOAL
May the farce be with you
Jun 9, 2012
4,433
:roflmao: :roflmao: :roflmao:
Guys, it looks like he has an LB7, doesn't seem to know a whole lot and just "attempted" to swap injectors...
$10 says he's "making oil"
Big Block 88
Multiple choice muscle
Nov 3, 2008
4,665
Kansas when I am home
When you changed injectors did you change the spark plugs? There are 2 per cylinder like a hemi, they are located in the valley behind and above turbo to the left of the DEF tank... Could also be the spark control box, they are very hard to find on a diesel so bear with me... Located under the left motor mount, in the aft oil pan on the starboard side of the cp3 inside the transmission valve body upside down and inverted.
Hot COCOAL
Jun 9, 2012
4,433
When I had spark issues I checked and redundantly replaced everything...
Then I dug deeper and my worst fears were confirmed...
Yup
It was the Flux Capacitor...
That, and I was low on plutonium, I wasn't making 1.21 giggawatts anymore and the flux capacitor wasn't able to control the injectors duty cycle and as it turns out, a duramax won't fire with anything less than the 1.21 giggawatts anyways
So a quick trip to my local extreme duty electrical supply store and the nearby uranium/plutonium distribution hub and I was ret ta go yo
:coolspot:
