Hey guys,haven't been on in a while but I'm in need of some help.
I had an issue with a bad oil leak and wound up pulling the passenger side head.It wound up being a bad valve seal on the stem,finaly got around to putting it back together and I had issues with the lift pump not working from sitting so long.Took the pump apart cleaned it and it worked soooooo now the truck starts for a sec then shuts off it does this everytime.I took a line loose and it sprays fuel out,didn't see any air even tho I deleted my top side filter.The battery's are fully charged and the charger is on it to back up the battery's so it cranks fine.I rechecked all wiring and it all seems to be connected well.What am i missing????Thanks in advance for any help guys much appreciated.:hug:
