no reverse or neutal
ripmf666
15,123
14
47
Wentzville Mo
Like Kat said any codes ? Your saying no reverse or neutral what is it doing when you try this. What's it do when you put it in drive. I see your from Kansas I'm in Kansas city mo over off I435 by Worlds Of Fun. If you do not have the codes scanned or and thing figured out by the time I'm back from Md around Wed I will come and give you a hand.
bradyn
Sep 22, 2010
kansas
No codes. It will sometimes go backwards in reverse, and it will sometimes go forward, goes forward in neutral. Forward in all gears except park. About 20 minutes from topeka.
ripmf666
15,123
14
47
Wentzville Mo
Also info like it was just rebuilt the night before would be info to post when asking for help then atleast say what kit your working with.
bradyn
Sep 22, 2010
kansas
Alto clutches kolene steels transgo shift kit adrenaline performance nodded c1 and c3 plates.
bradyn
Sep 22, 2010
kansas
It went in but it was super tight, I had to align c1s prior to the snap to.g to get that cover on they would not move with the two snap rings in.
bradyn
Sep 22, 2010
kansas
Yeah I'm going to, thanks. It's a bummer but that was the only issue I had, I should have consulted sooner I guess.
bradyn
Sep 22, 2010
kansas
Well everything turned out great after i swapped the spiral snap ring with the more conventional one.
THEFERMANATOR
LEGALLY INSANE
Feb 16, 2009
3,890
ZEPHYRHILLS, FL
Are you talking aout the C1 or the C4? If the C1 you do know there is 2 snap rings that go in it right. And I have found that both of my 01 trannies require different shimming than just a clutch pack swap. When I put the C1 in I found the ALTO pack to be about 30 thousands thicker than the pack I took out so I had to get a differrent selective plate for it. And there are 2 differrent apply plates available for the C1 ALTO pack as well depending on wether it is a 5 or 6 speed.
bradyn
Sep 22, 2010
kansas
The snap rings were backwards in the c1 I swapped them, I put the regular snap ring In first and then the spiral ring.
bradyn
Sep 22, 2010
kansas
The clearances were good, right where alto said they would be, mine is an 04 idk if theres a difference between mine and your 01. But everything seems perfect so far. No problems at all.
