LBZ: No reverse after rebuild
gmac32
288
3
bellville ohio
I just refreshed a customer's trans and now there is no reverse. Goes forward in the shop but haven't drove it. Doesn't throw any codes at all. That is what has me stumped. I put it in reverse and it says " shift range inhibited" is there a way to make it go hydraulic reverse or third like the 5 speeds?
Cougar281
1,808
251
St Louis, MO
No codes at all when you put it in reverse and get shift range inhibited? A LONG time ago, I had something similar happen where when I put it in reverse that would happen but there was a code (don't recall what it was). Problem was an o ring for one of the pressure switches in the psm was out of place and leaking pressure.
Sent from my 2PZC5 using Tapatalk
Mattsmax
90
Barboursville, VA
I’m no genius but I’d guess valve body since there is no codes. Check your springs and make sure all the valves move freely.
Make sure your speed sensors are hooked up as well
But start the truck. Pull the main harness on back of trans. If it doesn’t have third and reverse like that then something internally is wrong somewhere
SoCal66
Sep 15, 2019
Not to spoil anyone’s fun but...
Me thinks it’s time to check your NSBU Switch...
Start simple, go from there
Also check battery voltage (and each battery to check for bad one), fluid levels, etc.
15,681
It's a 6 speed, no NSBU. Battery voltage would inhibit forward gears as well; so would low fluid.
SoCal66
Sep 15, 2019
^ Good Catch...
Guessing now...Pressure Switch Manifold related?
Possibly TCM related, broken/backed-out wires?
Bowing out. Good luck. Hope you get it fixed quickly.
gmac32
288
3
bellville ohio
I tried another tcm and no change. Took the valve body out and everything stroked freely. Speed sensors are working right. It will power brake and spin the tires so i know i have enough pressure for reverse. I have done all these things and this is why i am confused.
Mattsmax
90
Barboursville, VA
Crank the truck then pull main harness on back of trans, put it in reverse. Does it have it then?
