A freind of mine just got an ECM from ECUOutlet for his 07 LMM, and had it programmed with his OS (12628594) from his VIN. Now the remote start doesn't work. Initially, I suspect it was becuase the injector flow rates hadn't been programmed. I programmed the flow rates from the GPCM to the ECM. It then wouldn't work, probably because the DPF was removed, but not tuned out at that point. Now he has a Quadzilla with the DPF delete program in it, and the remote start STILL doesn't work. I noticed that there where some DPF related code that where coming and going. They never matured, and didn't set a MIL, they showed up in the V2, but not in the 7.5 scan tool. Below are the DTC's as they where recorded with the "Record all diags" function. Any suggestions? I may end up using a license and hooking him up with a EFILive DPF Delete tune. Might work better.... Also, the "Remote vehicle start disable 1" data is "Unknown"m and there are no more entried...just in 1.
P2033=ECM,-F---N-S
P0420=ECM,-F---N-S
P2455=ECM,-F---N-S
P0546=ECM,-F---N-S
P2033=ECM,-F---N-S
P0420=ECM,-F---N-S
P2455=ECM,-F---N-S
P0546=ECM,-F---N-S
