No rail pressure!
dracing70
SH--- GETTING EXPENSIVE!
Jun 12, 2007
1,210
45
mantua, oh
Ok I inquired about this situation before. We bought a engine from a guy on here some months back. It was supposed to b a lmm but turned out to b a lbz. He promised the engine was low mileage and in perfect running cond. my brothers mechanic has been dicking with this thing in Florida for two weeks. They orderd a brand new wiring harness switched all the necessities and have taken apart four times and still r not getting any rail pressure. We need some help and a direction and I will also notate after all of this this persons identity for future buyers to beware. All injectors r getting signal and cp3 was even switched yet still no rail pressure. Remember they r putting a lbz into a lmm
dracing70
Jun 12, 2007
1,210
45
mantua, oh
So apparently after the new harness was swapped out do to a hacked up harness the truck fired ran perfect for a min. Then barreled black smoke and rattled and shut down. Now it will not restart. Only getting about 400 psi of rail pressure. Cp3 s have bee switched. Getting fuel return on the rubber hose by the driver firewall but no return from the injectors. The guy that sold the engine swore the injectors were new but we think he switched them out prior to shipping the engine. Does this sound like injectors r stuck open. ..?
bluecollar
351
ia
Well idk for sure but i just had a problem with my lbz pump returning fuel try pumping while cranking? But my issue seems to be rare
dracing70
Jun 12, 2007
1,210
45
mantua, oh
Pumping? As in the accelerator pedal? Or the manual pump. This truck has a lift pump and it's blowing fuel up to the cp3
sweetdiesel
That's better
Aug 6, 2006
10,390
52
Thailand
You could either pull the glow plugs and check for fuel blowing out
Or take a old injector line cut it and weld it shut then do each inject or individualy by placing the plug on the fuel rail
dracing70
Jun 12, 2007
1,210
45
mantua, oh
Crank sensor good. I told them to plug off one ink line at a time
bluecollar
351
ia
Yes mine had lift pump.. i had to pump primer while cranking. I just today swapped cp3.. i also took thethe rubber return line off my cp3 and pumped ther primer and fuel came out
5,855
Unplug the fpr if your concerned the ecm is telling it to be closed. Max rail will be commanded then.
dracing70
Jun 12, 2007
1,210
45
mantua, oh
Yeah we tried unplugging the fpr. Gonna pull the injectors and have them and cp3 tested and see if one of our fellow members really burned us. He has not answered our messages in over a month.
paint94979
Beer Nazi
Sep 18, 2006
11,715
37
Pm me, id like to know who it was that sold you this engine
May 8, 2011
68
when the truck did run was it rough running? only reason i ask is i delt with a lbz in to lly truck before and the tone rings on the crankshaft have a diffrent number of teeth some times it would run but timming way out of wack. Most of the time it would kick a little bit every now and then an rail pressure would be low. Im not sure what the lmms are running for tone ring number of teeth cant find it anywhere but i would look in to that there easy enough to count .
jkholder09
Jan 8, 2012
1,188
Maryland
with fpr unplugged it would go wide open if the barrell wasn't stuck shut.
What if the fpr is totally stuck shut?
the lmm or lbz want about 3k rail before injectors will fire
sweetdiesel
That's better
Aug 6, 2006
10,390
52
Thailand
Its worth checking but I'm 99% sure lbz and lmm are the same
Lly are different
