No rail pressure
Evan@InglewoodTrans
yerp
3,118
65
Western MA
I changed the injectors on the truck and now the truck has no rail pressure and I have no idea why ive been messing with it all day with no luck. Ive logged fuel rail pressure a few times and it stays at 150 psi wether just sitting with key on or cranking. However once this morning it spiked at 750 it seems to have gotten worse the more stuff ive tried lol. Here is what ive tried.
1 Made sure all the high pressure lines I touched and didnt touch are tight.
2 Disconnected fpr (just in case)
3 Cracked all the lines thinking maybe some air in the system. (on edit when i do there is fuel but it is foamy and full of air)
4 Removed the valve covers and reasembled the fuel lines to check for leaks
5 Checked and double checked the triple checked all electrical connections.
6 Only Pulled glow plugs on passenger side so far but no fuel coming out .
Any ideas ?
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
OK i would start with logging while cranking
then unplugg the regulator and see if it changes, if it does go to 160mpa then you know that the fuel rail sensor is working and you have no issues on the low pressure side.
if it doesnt change i would check the fuel rail sensor is plugged in and perhaps your FPR crapped out,
what about the fuse for the the injectors? check that?
get as much info as you can and eliminate all you can and we can figure it out:)
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
I know you said you checked all connections but injectors are all plugged in?
this may sound crazy but i had a reg stuck one time and gave it a FONZY tap and bang the truck fired:cool:
Evan@InglewoodTrans
yerp
3,118
65
Western MA
then unplugg the regulator and see if it changes, if it does go to 160mpa then you know that the fuel rail sensor is working and you have no issues on the low pressure side.This morning when logging fuel pressure it would change while cranking now it just sits right at 150 and doesnt change whether the fpr is plugged in or not.Either way it never got higher than 750 and that only happend once.
if it doesnt change i would check the fuel rail sensor is plugged in and perhaps your FPR crapped out,Checked the fuel rail sensor this morning and about 40 more times lol its plugged in
what about the fuse for the the injectors? check that? Not yet
Thanks for the help :hug: any suggestions are great.
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
if des FRP went to 160 + mpa when you unplugged the regulator then im going to geuss the regulator is fubared since it cant make that......ASSuming you dont have low pressure issues.
Check the pressure at the brass thing of a majingy by the alternator,If its a LB7 you can just pull the hose off behind the special fitting. you will know if you have pressure by putting your thumb over it;)
sweetdiesel
That's better
Aug 6, 2006
10,390
Thailand
for shits and giggles unplug the fuel rail sensor and crank it iver and log it.
this is a single cp3?
does your value change when boosting the battery?
Evan@InglewoodTrans
yerp
3,118
65
Western MA
I managed to screw somthing up during the process I would love to know what there isnt that much there that i messed with. I really need a another set of lines to do more testing so I can eliminate anything after the rail other than that im at a loss here.
Evan@InglewoodTrans
yerp
3,118
65
Western MA
Well after welding another set of feed lines shut and installing them to check if the problem was injector related I cranked a little bit and sure enough it built rail pressure fine. It's sucks but I'm just glad Im looking in the right spot now after tearing my hair out trying to figure it out.Thanks for the idea Trent :thumb:
TrentNell
Finally underway !!!!!
Jul 7, 2008
7,543
slc tuah
good to know , if you need me to get them tested to see which ones are bad let me know , and yes having HP caps to isolate parts of the system is invaluable to diagnosing RP problems , glad it help Evan .
Evan@InglewoodTrans
yerp
3,118
65
Western MA
I worked down the line replacing the full feed lines until rail pressure wouldnt build anymore to try and narrow the culprit or should I say culprits down.im just happy to hear the truck start. Thanks for all the suggestions simon i really appreaciate it :hug:
