No Prime To Fuel Filter
darkone98
Sep 12, 2012
134
Markerville, AB
So after getting home with a new fuel filter and changing it, I go to prime the filter and after 5 solid minutes of pumping, nothing. Tried with the gas cap off and bleed screw completely out and everything:(. Suprisingly, I managed to source a filter head rebuild kit locally in Red Deer, I'm hoping this will also resolve the random hard start issue I have had lately as if the injector lines had air in them.
MACKIN
Smell My Finger...
Aug 14, 2006
3,948
Connecticut
Good place to start with the rebuild of the filter head also consider a lift pump. Make sure the filter gasket is getting a good seal. And the WIF sensor o-ring even if you put a little Vaz on them. Good luck
darkone98
Sep 12, 2012
134
Markerville, AB
I'm certain the O-rings are sealed, I just picked up the rebuild kit this morning and am going to install it today. I planned on getting an Air Dog 165, but im still saving for my V2:woott:
darkone98
Sep 12, 2012
134
Markerville, AB
So it turns out the seals were fine, but i found large amounts of clear plastic shavings and rag lint inside those little non serviceable one-way valves, took me about a half hour with toothpicks and solvent to clear them. Serves me right from filling up from a slip tank with no filter. I installed the rebuild kit for piece of mind anyways, and all is well once again. Now on to solve that water pump leak...
