Went out this weekend and was doing my double tow. All lights, blinkers, brake lights were working for the truck, 5th wheel and side x side trailer. Go to come home and I have no brake lights(right side) for the 5th wheel and side x side trailer. The truck has brake lights. Its gotta be a fuse. I check all the related fuses and their all good. Visually and with continuity meter. I supply all the power(while towing) via the 5th hook up connector in the bed. I check it and the bumper connector and there's no power(only right side). I know the trailer and 5th are working by checking it with another vehicle. I pull the fuse for the right side(driver's fuse panel), apply the brake pedal and check with a continuity light. There is no power to either side of the fuse terminals. I double check the left side and get power out of one side. I'm at a loss here. Why do I not have power to the fuse block(drivers side fuse panel)? Need some help.
Thanks
Thanks
