You guys are gods in my eyes any help would be appreciated....
I'm running EFI with a mild 100hp tune...
My Truck is a California Emissions I took off all the EGR crap close to a year ago. Truck has allways run mint. I believe but I'm not positive I have always had a P2227 code because he ECM compares the BARO sensor to the exhaust gas recirculation (EGR) and I don't have the EGR system.
Well here's the problem. Took the truck out yesterday to do some towing ran great I go out this morning to go to the store and almost no power off the line. from a dig the truck usually spins the tires and give a puff of smoke. Nothing no power... After a few second the boost comes up and the truck starts moving. Boost at max is down only 3 pounds. Zero power off the line. Takes forever to get the boost up.
Using EFI I checked the balance rates there all with in 2- 2+ I commanded the fuel pressure to max and it went right to it. Then I drove around and logged and nothing seems odd except when the TPS is at %100 it takes for ever to start seeing boost....
any help would be great....
