LB7: No Communication
durallymax
Apr 26, 2008
2,756
Under The Hood
Working on our 02 LB7 that supposedly died while one of the workers was using it. Not clear on whether it died or stopped moving, heard two stories. One of the other guys tried starting it and said it just cranked and did not fire.
I finally got a chance to look at it yesterday and it acted dead so I threw the charger on it, still acted dead. Batteries are new but connections were very bad, cleaned them up and it cranks perfect now but still does not fire.
I noticed the fuel gauge read empty but its been doing that off and on, just to be sure though I filled it up before dragging it in the shop, only fit 9 gallons in it so thats not the issue. Good fuel at the filter as well.
After checking fuses and swapping relay's I decided to check the fuel rail pressure while cranking. This is where my issues came up. I was all excited because of my china Tech 2 so I hooked it up but whenever I try doing anything with the engine it says that it cannot establish communication. Now it is communicating with the truck because I was looking at a lot of other modules earlier and everything was fine, its just the ECM that it does not seem to want to connect to. I have successfully used the special features for the LB7 engine with this Tech 2 on other trucks already so I know it does work. To rule it out though I drug out my EFI Live and laptop and hooked them up, it connects to the vehicle fine but every parameter for the engine that I select it marks as invalid. This really led me to believe it has to be a communication issue with the ECM so I tried connecting to it with the DVT tool and nothing happened there either.
So I am not going to say this communication issue is my only problem, but it seems to be the place I need to start. I do have a U1255 (T-Case), U1016 (ECM), and U1024(TCM) loss of communication codes. I usually never pay any attention to those as they seem to mean very little on any other truck, but it seems I do truely have a communication issue this time. I just went out to try clearing those to see if any came back as I suspected they were from the low voltage issue before but now my EFI Live says it cannot detect a vehicle. I tried unplugging multiple times and still cannot get it to detect a vehicle anymore. So I hooked the Tech 2 up and it will clear the BCM codes but they come back immediately. u1255 is the only one showing up for some reason but I didn't spend too much time going into other modules looking for codes, that was the only DTC that was present and continues to come back in the BCM.
So I am guessing the bad connections could have caused this issue, is it possible the ECM itself is bricked? What else should I be checking? I can't remember if the truck will still crank with a bricked ECM or not, I didn't think so but could be wrong too.
I did find what was probably one of the initial issues that kept it from moving though, the NSBU switch does not appear to be communicating anything. I keep some of those around so I will try one, but maybe its not the switch and part of the gremlins I'm chasing. This truck has had a few lately, it will randomly show no fuel for some reason too. I will be cleaning the grounds to as it does live in corrosion, but looking for some other suggestions on the communication issue right now.
Sorry for the long winded post so early in the morning, thanks in advance though.
13,711
772
Did you check for power and ground at all the necessary locations in the ECM connectors?
durallymax
Apr 26, 2008
2,756
Under The Hood
Well I found my issue as much as I don't want to admit it. Damn chemo must be getting to my brain. I swore I checked every ECM, IGN or any related fuse but apparently I missed the 20a ECM B. After taking apart the C1 and C2 connectors and just testing for key off power and finding none, I found that fuse feeds the two orange wires that did not have power (Pin 20 and 57 on C1 IIRC). Put a new fuse in and buttoned everything up and it works as good as it did before anyways. PRNDL is working fine now as well. The signal must go through the ECM or something and without power it wouldn't read.
It could be due to my manuals being for an 03 and this truck being an 02 but the pink wire feeding pin 75 of the C1 is supposed to be hot all the time according to the book. It's fed from the IGN 0 fuse inside the cab. On this truck it is keyed. I know 03 they changed a lot of the wiring around so that could be it, either way seems to work fine now.
The real issue of course is why the fuse blew to begin with, could be a fluke could be a bad wire I guess if it happens again i will tear into it further. I did put my Loadpro on the wires to check the integrity of the wires and they tested good.
Now onto the multiple ABS issues I've been ignoring, and maybe the random fuel gauge going to zero. SIR decided to act up too, I've replaced the module under the seat twice and it fixes it for a few months then comes back. Damn Wisconsin winters.
13,711
772
FWIW, as far as I've seen on these trucks, solid pink wires are always ignition power wires. Glad you got it figured out, Vinny.
