No Brake Pressure, Power Steering Fine
Stancedlb7
Cummin Stroke this Duramax
Feb 9, 2015
649
SLC, UTAH
If you rub your fingers together, wet with the fluid of course, brake fluid will be grippy power steering will be slippery like oil. Also check you powersteering reservoir for fluid color. Sometimes people use atf, red, instead of powersteering.
rtrogers
Dec 29, 2016
11
Yeah haven't checked back in a while. The solution was not to be a dumbass: pin hole leak on the hydraulic hose line at caliper.
