nO bOTTOM
JRODS*LB7
Feb 1, 2012
642
SE Massachusetts
OK guy/gals. I get max 28psi boost even if i pinch off the waistgate line.Is this normal or do i have an issue somewhere ? fyi thats on max effort tune truck from dead stop no spool wot takes a lil bit before the tires to break free kinda like truck is lacking bottomend,up top goes like a raped ape,is my stock charger on the way out?Do i have a boost leak? seems to me with a maX EFFORT TUNE FROM ROB I SHOULD BE LIGHTING THE TIRES UP FROM HERE TO SHINOLA.aNYWAY I CALLED DUSTIN HE TOLD ME TO PINCH OFF THE WASTE GATE SEE IF I GET MORE PSI AND CHECK FOR BOOST LEAKS I DID BOTH TIGHTENED ALL THE HOSE CLAMPS LOOKED FOR TEARS OR HOLES ..ETC.. nADDA! wHAT ARE SOME OF YOUR OPINIONS ?iM GOING TO DATA LOG TOMMOROW AND SEND IT TO ROB.aNY OTHER POSSIBILITIES???:confused:
1,865
I'd bet its just how the tune is written so as to keep the low-end torque down to help the rods live at higher power levels. Best bet is to ask ATP what they think.
My hot tune cant/wont turn the tires over at all....but at 1/2 throttle on up, watch out. Boost ramps up to 32/33lbs just before shifts.
JRODS*LB7
Feb 1, 2012
642
SE Massachusetts
ya i notice that to half throttle feels more responsive my 33's probably dont help either with 18 them bastards are heavy
your boost ramp up to 33? is that a stock waiste gate?
Righteyeblind
712
Fairbanks, AK
Check the intercooler for leaks too. I found two in mine and they have been there since it came off the showroom floor. They didn't even weld it in two spots.
blk smoke lb7
<-----Lots of green $
Nov 8, 2010
5,694
57
belvidere,ill
pull the intercooler pipe off the charger and off the y bridge plug 1 end and go to Meanrds home depot or somekind of home improvemnt store you can use natural gas fittings to reduce down to 1/4 pipe thread.then get a 1/4 pipe thread tee put a gauge on 1 end and a small valve on the other and an air chuck into the valve.Its best to use a air regulator set to somwhere around 45 50 psi for continuse pressure because you have leaks you just dont know it yet ,all the lb7 intercoolers leak from the factory for the most part.You can try mixing up a runny soap solution in a spary bottle and spary all the fitting and conections to see if they are leaking,if they are there should be soap bubbles.Your probably going to find the bottom corners of the intercooler are bubbling away.
