no boost?
Dmaxpayton
Dec 21, 2010
5
So my truck threw a P0237 code. It came up as boost sensor circuit low. Ive been searching and i cant find the right answer. Where is exactly is the boost sensor? Is it in the intake runners by the heads in the valley in the motor? And does it have the same part number as the baro meter? please help! Its a 04.5 lly btw
Mike
hmmm....
Feb 17, 2007
2,184
San Angelo, TX
CIRCUIT DESCRIPTION
The boost sensor responds to pressure changes in the intake manifold. This pressure is created by the turbocharger and changes with accelerator pedal position (APP) and engine speed. The engine control module (ECM) uses this information to assist in diagnosis of the barometric pressure (BARO) sensor and to provide engine overboost protection. The boost sensor has a 5-volt reference circuit, a low reference circuit, and a signal circuit. The ECM supplies 5 volts to the boost sensor on a5-volt reference circuit, and provides a ground on a low reference circuit. The boost sensor provides a voltage signal to the ECM on a signal circuit relative to the pressure changes. The ECM monitors the boost sensor signal for voltage outside of the normal range. If the ECM detects a boost sensor signal voltage that is excessively low, this DTC will set.
CONDITIONS FOR RUNNING THE DTC
The ignition is ON.
CONDITIONS FOR SETTING THE DTC
The boost pressure is less than 38 kPa for 2 seconds.
ACTION TAKEN WHEN THE DTC SETS
  • The control module illuminates the malfunction indicator lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and fails.
  • The control module records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the control module stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the control module records the operating conditions at the time of the failure. The control module writes the operating conditions to the Freeze Frame and updates the Failure Records.
  • The ECM limits fuel delivery.
CONDITIONS FOR CLEARING THE MIL/DTC
  • The control module turns OFF the malfunction indicator lamp (MIL) after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
  • A current DTC, Last Test Failed, clears when the diagnostic runs and passes.
  • A history DTC clears after 40 consecutive warm-up cycles, if no failures are reported by this or any other emission related diagnostic.
  • Clear the MIL and the DTC with a scan tool.
TEST DESCRIPTION
155335391
Steps 1-4
110610818
Steps 5-9
158740470
Steps 10-14
The numbers below refer to the step numbers on the diagnostic table.
  1. The boost sensor 5-volt reference circuit is shared with other sensors. If DTC P0651 is set, this indicates that the 5-volt reference circuit is shorted to ground and should be diagnosed first. The short may be on another sensor 5-volt reference circuit.
  1. If you cannot duplicate the DTC, the information included in the Freeze Frame/Failure Records data can aid in locating an intermittent condition.
Mike
hmmm....
Feb 17, 2007
2,184
San Angelo, TX
Any chance your boost sensor is unplugged? Yes, your sensor is behind the a/c compressor in the drivers side manifold.
Dmaxpayton
Dec 21, 2010
5
well i just replaced and it wasnt unplugged but now its throwing a boost control sensor and boost control solenoid any chance of knowing where they are located
