For the guys who run spray, do you find the HP rating of the jets in the Diesel kits to be accurate? I am set to run a .054 whick according to ZEX is a 125hp jet. would this be close? I always here guys running .088 or bigger.
Kelly
Nitrous jetting in a diesel and HP ratings for gassers are far from close.
It is dependent on lots of engine factors such as timing, duration, fuel presure(High) and (low)sides, turbo size, back pressure, boost levels, CR, Outside temp, engine temp, and rpm encountered.
Then you have to consider the bottle itself, like: what psi is the bottle at?, what temp is the bottle at? where is the bottle mounted, what size lines are feeding your solonoids and even the nozzels size.
Just these issues here can result in a power decrease as much as 300HP+ in a diesel.
the best thing to do if your new to nitrous is to tune it by sound of engine( no loud noise or popping), and only increase jet size as untill smoke clears up, and dont inject it untill at least 20psi or 2k rpm!!!!!!!
start with a small jet like a .20 and move up from there dependant of the areas i covered above.
