LB7: Nick tane conversion.
kking
~only stock for now~
Mar 20, 2013
81
Il
Has anyone had any problems with this kit, my truck is loosing prime still I have found all the other problems I originally had but still losing prime. When they want you to remove the check ball in the filter head would this cause any issues with loosing prime at all?
DBUSHLB7
Team DMAX
Mar 9, 2012
2,789
Albuquerque, NM
kking
Mar 20, 2013
81
Il
Ive had too many problems with this truck so far, it's loosing prime from some where and I've done all I can do last time I found a reman injector line that was junk and that was causing all my fuel in the oil, pulled a vacuum on the return lines it held for hours.now I have no fuel in the oil just hard starting and loosing prime and dying when I start it up. Thanks for the vids though that's where I ordered the rebuid kit when I replaced my injectors everything I have bought has been through them.
kking
Mar 20, 2013
81
Il
Sorry about that I should have said I rebuilt it. Just didn't know it the problem would be related with taking the check ball out. When the injectors were replaced I went through and replaced the lines with oem ones expensive to do, If it isn't one thing it's another with my lb7:D
