Hey everybody, so i stole the idea from DuramaxD here on the forum to install a nexus 7 in the dash of my truck instead of using a standard headunit. I got the idea from him but didnt get much information on how to actually do it including the software needed on the nexus so here goes my first how to write up.
Note: Im terrible at taking pictures as i go, so i will update with more pictures by the end of the week
Parts Needed
• Nexus 7(2013 Model)- http://www.amazon.com/Nexus-Google-7-Inch-Black-Tablet/dp/B00DVFLJDS/ref=sr_1_2?s=electronics&ie=UTF8&qid=1460597000&sr=1-2&keywords=nexus+7
• USB OTG Y cable- http://www.ebay.com/itm/191805977770?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
• USB DAC- http://www.amazon.com/Behringer-UCA222-BEHRINGER-U-CONTROL/dp/B0023BYDHK?ie=UTF8&psc=1&redirect=true&ref_=od_aui_detailpages00
• USB Hub- http://www.amazon.com/StarTech-com-Mountable-Rugged-Industrial-ST4200USBM/dp/B001H7AFO6?ie=UTF8&psc=1&redirect=true&ref_=od_aui_detailpages00
• Car Audio Amp of your choice
• Speakers Of Choice
• Hard Case To Fabricate Mount
• Stock Radio Or other Mounting Kit
On the Tech side of things is where I got a little complicated, I Rooted the nexus tablet and installed a custom Kernel from Timnur https://timur.mobi/timurs-kernel-n7-2013/ What this Kernel does is gives the tablet the ability to send Audio out of the USB through the OTG Y Cable, it also allows for Fixed Installation Mode, Which will power the device up when it gets power from the ignition on, and will power the device into a deep sleep) when it loses battery power, this allows the tablet to remain charged without drawing from your car battery for longer periods of time than if you just put it to sleep. Then when power is returned to the device during ignition, it immediately boots back up for use.
Once this process is done it is really smooth sailing. I went to the junkyard and found a water damaged stock radio for $12 and gutted it down to the shell. I used this to mount my components inside of, and I epoxied my tablet case to the front side similar to a double din, after some adjustment it sits perfectly behind the bezel of my truck with zero modification to alter the bezel.
The only wiring required at the tablet is
Ignition Power
Ground
RCA Audio Out(to Speaker Amplifier)
I stole the power and ground from the stock harness
For my amplifier I used a crunch amp set to 3 channels 1-2 for my left right speaker output, and 3 for mono subwoofer output
For now I do all of my audio using Spotify, but you can use whatever music application you find to streamline your listening experience
Steering wheel control Integration will be coming soon using a Joycon EXR http://www.ebay.com/itm/CarPC-JoyCon-EXR-/160850527712?hash=item25737045e0:g5IAAOxyoA1RNT-s
Parts Needed
Ignition Power
Ground
