Newly purchased stock 2008 K2500 with 232k miles
midgainc
Feb 20, 2016
Bolingbroke, GA
I have had a 95 k2500 diesel for 10 years and decided to upgrade this weekend. I found a pristine bone stock 2008 that was owned by an old man. Hardly a scratch on it and the underside looks brand new. The old guy pulled a gooseneck trailer ome. That is all I know about.
On my 6.5 I drove it 5 years before I researched why it was so sluggish. It has a REDUCER tail pipe tip, and still had factory soot box. I plugged vac line to EGRand cut soot box out and it came ALIVE. Since then I put in Diamond Eye exhaust etc. So, I know the Duramax needs to breathe too.
I am certain the EGR system looks like crap since it is all hooked up.
What is the first thing you guys would recommend doing to this engine?
Everything I can find says EGR delete, DPF delete, PCV re-route, and re-program. What is the most bang for your buck, and what order would you do these in if you couldn't do them all at once?
Also, on the PCV re route, why can't it be routed to return between the turbo and intake manifold to eliminate oil vapors on turbo, and still allow them to be burned? I don't want to smell engine vapors. Is it a bad thing to run the oil vapors back through the Engine? It's not like hot exhaust gases (EGR).
Please advise. I plan on keeping this truck for a long time, and this time around, I want to get the best fuel economy and power from the beginning of ownership instead of 5 years later!
Thanks.
melms23
253
WI
The cheap way: blocker plate between up pipe and egr cooler, use heater hose or similar spliced into the pcv crossover and plug the hole in the intake. Then tune and exhaust.
More expensive way: delete egr cooler all together with a delete pipe and modified up pipe or lb7 style without riser. Vendors kit with fittings and hose for pcv. Tune and exhaust.
Search around. There are many, many topics on this. By the way, welcome!
delong_1
<< my work
Dec 5, 2008
1,282
Arvada, CO
If you vent the breather after the turbo it would pressurize the crank case. The complete opposite of what you want.
dzimbric
86
Shallotte, NC
what is the benefit of the egr delete? I have the same year truck that I have owned since new and just recently replaced the exhaust and intake and added a tune by Diesel Addiction.
