Newby with cooling system Q
HurricaneWayne
May 18, 2014
So I've browsed thru old posts and seen what is likely the answer. I have an 03 2500HD. Im loosing a gallon of water a day in the system. The water is escaping in the area where the transmition and the engine come together. I recently had an Edge Evolution installed. The motor runs approx. 210 however a few days ago it got up to 220-230. The engine has approx. 230,000 miles. Most likely will take to the dealer, but would like and insite from experts. Thanks.
5,818
Could be a head, could be the back plate in the mid plate for the crossover, could be a freeze plug,
HurricaneWayne
May 18, 2014
I like the freeze plug idea. Can anyone tell me how to pressure test the cooling system, and check the freeze plugs for that matter.
metron
Sep 13, 2012
195
Buffalo, NY
Get a cooling system pressure tester. Its a hand pump that goes on your radiator cap. You slowly pump it building pressure in the system then look for leaks.
